    Ennoid MK8 Vesc
      Lemur last edited by
      I just received the Ennoid MK8 with the BT module.
      I rewired a stock XR/Plus power switch as the MK8 needs a momentary NC switch, the stock XR switch is wired NO, but has a NC terminal on the switch, the led lights up fine on 5v, normal XR/Plus led is fed by 12v.
      This switch makes using the stock XR controller box a lot easier.
      The 6.05 firmware is already loaded in out of the box.
      I will be running 24s1p Molicel 45b for now and a Stokedstock bmsIMG_E9528[1].JPG
        @lemur 24s1p sounds wild! Can't wait to see that ^-^
