    Gt ubox100 build
      Lemur last edited by
      I went backwards with my Gt/Ubox 100 build..
      I switched out the SF motor back to the Hypercore motor although the GT motor now has a 6 inch rotor, 14 bolt end cover with an actual oil seal. Special axle blocks were made to center the wheel.
      This is not my main ride and the extra 5 lbs of the SF is not worth the torque gain. I'll save the SF motor for another build.
      The Ubox 100 has been updated to 6.05 "no limits" firmware and refloat.
      The external yellow XT90 connector is a quick disconnect so the battery is not connected in storage to avoid parasitic draw.IMG_E8890[1].JPG IMG_E8888[1].JPG IMG_8884[1].JPG
        @lemur hands down one of the cleanest installs ive seen.
