    Gt sub board for vesc
      Lemur last edited by
      Much like the Pint sub board, the Gt sub board can be used to convert your dead GT to vesc.
      Mine came from a traded in GT controller that had shorted mosfets and caps and it wasn't worth the time and effort to repair.
      You can add pulldown resistors 5k-10k to the adc's to ground if your vesc does not have built in resistors.
      The ground trace has to be cut just like the Pint sub board but they are in different areas.
      You can connect wires to either the motor connector backside or the 10 position terminal on the bottom right.
      As always please check your work before plugging anything inIMG_E8575.JPG IMG_8576.JPG
      LOAF 1 Reply Last reply Reply Quote 5
        LOAF XR @Lemur last edited by
        @lemur great work!
        Can I add this to the VESC Bible?
          Lemur @LOAF last edited by
          @loaffette NP.
          Go for it.
