    Adapting a Superflux to run in a XR, GT and maybe a GTS(not tested)
      Lemur last edited by Lemur
      I posted on FB too
      Requires a moderate skill level involving a bit of dremel or machining, and soldering.
      Parts needed 3 x 41f hall sensors, OW hall pcb board from a HC stator or a Pickles hall pcb. I have not tested The Pickles hall pcb, I used an OW one. I also used JB weld to pot the 41F halls and custom axle blocks, but aftermarket axle adapters are available. Wiring has to be custom made, in my case, I bypassed the stock GT motor connector, used 12 gauge phase wires with bullet connectors and custom hall wires all coming out the side of the controller box.
      That's just one way for the wiring, the stock motor connector can also be adapted, but I didn't like the wimpy stock connector.
      Very important, you must switch the yellow and green phase wires.
      I have tested this mod on Xr, GT, and Vesc, I have two SF motors modified this way and have performed great as this mod minicks a HC motor but is more heat tolerant.
      I have not tested this on a GTS as I don't have a GTS.
      LInk to Pickles hall pcb https://pickleworks.ca/.../fudged-hall-sensor-replacement...
      Lia 1 Reply Last reply Reply Quote 5
        @lemur I hope people understand how impressive this actually is. Nice work!
