    XR rear LED Pinout
    1352
      peepermeeper last edited by
      Does anyone know this? Id like to use it with the thor300 if possible
        Lemur @peepermeeper last edited by
        The red leds use orange for positive and grey for negative
        The white leds use yellow for positive and magenta for negative .
        I'm not sure you can use the Xr rear light strip for Thor as I believe the Thor light controller is for rgb(w) . IMG_8219[1].JPG
        P LOAF 2 Replies Last reply Reply Quote 2
          peepermeeper @Lemur last edited by
          @lemur Thank you !! and I think you are right about that I'm going to go with something else!
            LOAF XR @Lemur last edited by
            @lemur do you by any chance know what voltage the LEDs run at?
            L 2 Replies Last reply Reply Quote 0
              Lemur @LOAF last edited by
              @loaffette I can't remember, but I believe each color runs at a different voltage.
              I will find out and let you know.
              LOAF Sirgu 2 Replies Last reply Reply Quote 1
                @lemur alright, thank you!
                  Sirgu XR @Lemur last edited by
                  @Lemur said :
                  ... , but I believe each color runs at a different voltage.
                  I'm also curious and following this.
                    @loaffette The red leds run bright at 8v and the white leds run at 14v on my variable power supply. Although they can run a volt or two higher, but 8v and 14 volts are safe
                      @lemur so idealy I could run the white LEDs at 12V?
                        @loaffette 12 volts may be too dim as when the Xr boots up, the white leds voltage shoots up to 18v and drops down to 16v. I mentioned 14 v just to be on the low side.
                        LOAF 1 Reply Last reply Reply Quote 0
                          @lemur damn, got it
                          thank you
