    Onewheel GT 6.5 inch tire solution (hopefully)
    8261
      biell Plus GT DIY @Lemur last edited by
      @lemur Are we sure they used a 45? If so, you want to get an ip45 (Torx Plus), not a T45 (standard Torx). I don't get my GT until Wednesday (hopefully), so I can't guarantee this work, but if you say it is a 45, then it will:
      https://www.mcmaster.com/54305A33
      You will also need an adapter for your ratchet. Note that is a 5/16" hex on the bottom. Once you break it loose, a T45 should be fine:
      https://www.mcmaster.com/6963A26
      If you saw the picture of the TFL slick GT with the Life Savers on, you will notice they totally jacked up the bolt. My guess is they were using a T40 when an ip45 was needed. I am also wondering if FM is using loctite red.
        Lemur @biell last edited by
        @biell It's definitely a Torx plus, I can get one with 3/8 " drive from our Snapon dealer at a price of a complete set of a off brand. I don't want to mark up the bolts in case of warranty. I broke a couple of cheap bits on Pint rail bolts until I got a Snapon Torx.
          ed_co XR @Lia last edited by
          @lia said in Onewheel GT 6.5 inch tire solution (hopefully):
          @lemur Oh I get it now, was so confused at first but this makes sense. Instead of modifying the GT stator by shaving off that extended lip you're just shimming the hub plate to it can sit on the extended lip.
          That is so clever, I'd have never thought to do it that way! This is by far the best and least destructive method and I love it.
          Call me stupid, but I still don't understand the idea...
            Lemur @ed_co last edited by
            @ed_co It does get confusing, but the new Onewheel GT has a 6.5 inch rim and tires are proprietary which you cannot buy from OW. You have to send the GT in to get a tire changed.
            This adapter allows the 6 inch rim from a XR to be fitted to the GT and allows many styles of common 6 inch go kart tires from many sources.
              ed_co XR @Lemur last edited by
              @lemur said in Onewheel GT 6.5 inch tire solution (hopefully):
              I am well aware about the size change from XR to GT. But I don't understand the solution. Are you planning to put the GT rotor inside the XR stator assuming all the magnets/space/configuration will be the same on both?
                @ed_co The other way around, GT stator in a XR rotor (rim).
                E 1 Reply Last reply Reply Quote 4
                  ed_co XR @Lemur last edited by ed_co
                  @lemur
                  Source: https://www.facebook.com/photo/?fbid=10220209549740881&set=pcb.978722056102633
                  I guess you have all the answers here:
                  275777425_10220209549620878_6935716758871604536_n.jpeg 275685085_10220209560101140_4866607758880254349_n.jpeg 275618778_10220209561541176_3864382129661908584_n.jpeg 275898358_10220209547780832_4953507255042636824_n.jpeg 275933708_10220209565261269_4741119165093054503_n.jpeg
                  L 1 Reply Last reply Reply Quote 5
                    @ed_co Looks like there's no problem taking apart the motor.
                      Absolutelly, are you doing it?
                      L 2 Replies Last reply Reply Quote 3
                        Lemur @ed_co last edited by Lemur
                        @ed_co Picking up an expensive Snapon torx plus 45 right now to take the GT axle bolts off. One Snapon socket is the same price as a set of OTC TP sockets. I disconnected the GT motor , footpad cables, reconnected them and the board is still good.
                          @ed_co Did the conversion today, I have to make another shim as the present one is a little too thin, leaving too little axle endplay. It runs ,but can't upload a video. IMG_5261-1.jpg IMG_5260-1.jpg drawing.jpg
                          E NotSure Lia 3 Replies Last reply Reply Quote 7
                            @lemur this is absolutely stunning man!! Congrats, you did it!
                              @lemur lol yeah man thats fuckin awesome!
                                @lemur Amazing work!
                                For a vid I'd recommend uploading to Youtube and linking it here if you can.
                                Would love to see this working. Barely a week after launch and the community is undoing these roadblocks.
                                  MacIak DIY GT XR Plus last edited by
                                  Great work! How is the clearance on the footpad sides, looks marginal or just the img?
                                  Aka "Vommbat"
                                    ed_co XR last edited by ed_co
                                    Any change/improvement/news? Overcoming the wheel issue sounds outstanding TBH.
                                    The promised wheels from C&R and TFL sounds a very expensive solution, there would be a bump in the price for sure... (the new tooling system the companies could require for a custom solution makes it much more expensive).
                                      Lemur @MacIak last edited by
                                      @maciak The clearance is close, The wheel is moved over to one side by 1/8" due to hub differences. The stock tire is very close to the footpads too.
