    Tips on painting?
      Franko Pint last edited by
      Hi all -- i've painted my fender many times, but now i think the time has come to strip off the many layers of paint i have on mine and start from a clean base before putting on a new paint scheme. Anyone have any tips on what to use and how to strip it off? I googled around some, and there are many, many products made to strip paint out there (of course), but i suspect they are more for wood or metal, and i'm concerned about damaging the plastic. One tip said to use oven cleaner (!!), and i'm tempted because i have it on hand, but... any idea if it will work?
      Sage OG Pint (Battleborn Floater)
        NotSure XR Pint @Franko last edited by
        @franko said in Tips on painting?:
        what primer u use?
        Franko 1 Reply Last reply Reply Quote 1
          Franko Pint @NotSure last edited by
          @notsure i just used a standard can of Rustoleum primer for plastics. that worked great. Does it make a difference when stripping paint?
          Sirgu 1 Reply Last reply Reply Quote 2
            Sirgu XR @Franko last edited by
            @franko I dunno if this issue have solved already for you.
            But use dr.Google with keywords 'DOT4 brake fluid + paint removing + plastic'
            Motocyclists with loads of painted plastic parts talk about this (+ other methods) on their forums.
            Franko 1 Reply Last reply Reply Quote 4
              Franko Pint @Sirgu last edited by
              @sirgu ooh, thank you. i haven't started yet, still shopping for paint, so i'll look this up.
