    XR front LED’s identity
    8123
      Lia GT XR Pint Plus V1 DIY @Puzz360 last edited by
      @puzz360 I had similar. Turned out I had a cracked solder joint on the actual connector so you might have luck just redoing the joints :)
      Puzz360 1 Reply Last reply Reply Quote 2
      • Puzz360
        Puzz360 XR Pint V1 @Ando last edited by
        @ando I am with you on that one… I’ve been running with lights off for a while now.
        Next time I’m due for a tyre change I may well open up the controller again and check @Lia’s recommendation of a solder joint issue on the main pcb.
        Will post a video of the issue here I think…
        • Puzz360
          Puzz360 XR Pint V1 @Lia last edited by
          @lia I hope it’s something relatively straightforward like that. Cheers.
            @puzz360 said in XR front LED’s identity:
            My break was led side but good to redo both
            Puzz360 1 Reply Last reply Reply Quote 1
            • Puzz360
              @lia see attached link
              Short video here
              If that works....
              The LEDs go off when pressure is applied to the sensor (either one) they are very faintly on at times too.
              Generally they don't come back on while it's stationary but they can do.... Quite random.
              Not easy to capture without riding....
                @puzz360 That’s much weirder than expected. Tapping the pads engages the full brightness. I wonder if the drivers are becoming overloaded somehow.
                If you rotate the wheel a little to get it change direction does the fault remain?
                • Puzz360
                  Puzz360 XR Pint V1 @Lia last edited by Puzz360
                  @lia Yeah, weird indeed. What you say makes sense in a way because yes, it does engage full brightness.
                  I hadn't really noticed they are like soft start... Both directions.
                  Just trying again I notice that the LEDs will work ok (just an occasional flicker) when the board is just left on.... I can hear a faint electrical hum when they are on. (Ear close to the controller)
                  If I engage the sensor they go full bright and then off.
                  I switched them off with the app and they then carried on flickering very dimly even when I pressed the sensor. It almost looked like a cap gradually discharging until after say 30 seconds to a minute the LEDs went off ...
                  It must be the driver I suppose because it's a new LED strip and cable (screened/shielded)
                  Maybe getting overloaded on full brightness....?
                  Need to swap the rear driver for the front hahaha
                  If I rotate the wheel back and forth they just stay off once full brightness engaged.
                  If I don't engage the sensor I can roll back and forth and the LEDs keep working.
                    @puzz360 If you do open it again take a pic of the driver area. Might be worth checking the physical state if the inductors near the connectors on the reverse side.
