    Suspension board upgrades
      Lemur last edited by
      I upgraded my suspension board with a Fox shock and a Jw extended battery. This board is my lazy day ride when my legs are tired and I don't feel like watching out for bumps.
      This board is based on a XR controller and a Pint wheel. It took a bit of trail and error to find the right combination of phase and hall wires as the Pint wheel spins the opposite from the XR motor.
      The low end Fox shock is miles ahead of the offshore shock I had on before and it has the "float " labelling.
      My next suspension build (wip) will be based on the full size XR motor or Superflux.suspension board-1.png
      blkdout 1 Reply Last reply Reply Quote 6
      • blkdout
        blkdout @Lemur last edited by
        @lemur Sick build!
        Was finding phase a combination of both Hall and Motor? I assumed it would be swapping just 2 wires one or the other.
          Lemur @blkdout last edited by Lemur
          @blkdout There were 36 combinations (afair), two combinations worked.
          I made a list and started crossing off the ones that didn't work, the ones that didn't work either made growling noises or studdered. I used an expendable Plus controller to test as I didn't want to damage a XR controller and bms.
          I may try that on a SF motor just to get that idea out of the way.
            @lemur said in Suspension board upgrades:
            backward n forward?
              Lemur @NotSure last edited by
              @notsure I'm not sure what you mean, but only two combination of hall and phase wires made the board work normally.
                @lemur just my brain struggling to understand. apologies for my uninvited remarks..
