    Kush low as front footpad
    5692
      MacIak DIY GT XR Plus @NotSure last edited by
      @notsure
      Neither lol, hand laminated using the bottom of the pad for shaping since the front part curves up.
      3(or 4, dont remember) layers of unidirectional 340g/m2 fiber.
      Aka "Vommbat"
        MacIak DIY GT XR Plus @Sirgu last edited by
        @sirgu really like this. Im curious what it looks like under that grip!
        Aka "Vommbat"
          NotSure XR Pint @MacIak last edited by
          @maciak said in Kush low as front footpad:
          Kush-lo+ pint sensor.
          i wonder if this could be done for the airpad? it already has a sturdy base plate. i never tried peeling off the gel tho. i'd love that. id buy it immediately.
          M 1 Reply Last reply Reply Quote 1
            @notsure said in Kush low as front footpad:
            Is the gel part not inside the pad?
            Aka "Vommbat"
              that whole yellow piece is the "gel". its just soft rubber. under that is an aluminum base plate that provides the rigidity.
                @notsure
                I get it. Well, it depends. If that pad flexes enough so the toeside pressure deforms the heelside for instance, it could lead to undesired behaviour : such as heel-lift at standstill wont disengage the board.
                Also i can think of slow recovery of the pad back into shape after compression. So the moment you lift your foot the pad stays in that shape a bit longer. This would certainly lead to ghosting.
                I think you can determine by the feel of that pad if it has any characteristics i described above.
                Aka "Vommbat"
                  NotSure XR Pint @MacIak last edited by NotSure
                  thats a good point. what if the sensors are applied to the aluminum instead of the pad and covered with a low friction film of some kind? maybe kapton or pfte tape? the rubber does compress easily but it does not travel with respect to the base.
                    @notsure
                    Yes, a guy on the Onewheel subreddit is using it successfully like that. Here's a link to one of his posts:
                    link text
                    Aka "Vommbat"
                      Sirgu XR @MacIak last edited by
                      @maciak Yea, the day I posted it I had no idea the PlatySense v4 design involves single pressure sensor. Which is bummer for me. I'm keen on heel-lift disengage. :/
                      For now there's bunch of FB short vids of how on point sensitive it turned out.
                      Recent YT video here:
                      https://www.youtube.com/watch?v=JmKEnJOfZJM&ab_channel=BartMiller
                      M 1 Reply Last reply Reply Quote 3
                        MacIak DIY GT XR Plus @Sirgu last edited by MacIak
                        @sirgu
                        Oh dang! I watched that vid but missed the single sensor part coz i got pissed off by how he was slamming on the stock pad like an ape. This vid is very stupid tbh.
                        Edit: I dont like posi either tbh. The dual pad is about the only fail-safe we have and im no trickster.
                        Aka "Vommbat"
