    Stokedstock BMS
      thihan last edited by
      Does anyone know the correct plugging orientation for the BMS? Is it balance leads, power cable (XT60) then the charging cables? (xt30) Thank you in advance!
        Lemur @thihan last edited by Lemur
        @thihan This is from the Indy speed control llc which has taken over the sales of the SSbms.
        "When assembling the wiring, first connect the negative pole of the battery pack, i.e. B-, then connect
        the battery sampling line, and finally connect the B+ line to the positive pole of the battery pack. The
        charger can only be added after all the connecting wires are installed. The power-off sequence is opposite
        to the power-on sequence. You must strictly follow the power-on sequence requirements to avoid damage".
        https://static1.squarespace.com/static/612d35faee7c3b7ba3e07b7a/t/689c83a8a1b3fd4db0bd832e/1755087784984/DataSheet+Latest.pdf
        T 1 Reply Last reply Reply Quote 0
          thihan @Lemur last edited by
          @lemur thank you
