    Pint factory mode (blue/yellow light)
      Blankman last edited by
      I was trying to downgrade my pint and I overlooked the program that my motherboard had and I think I made it worse, I know there is a way to recover it with the st link, but I can't find the procedure, if can help me I'd appreciate it.
        Lemur @Blankman last edited by
        @blankman Dowgrading with stlink requires that you have extracted your bootloader and settings for the correct serial number, mileage.
        If you use someone else's bootloader and settings then you need a special program to change the serial number, mileage.
        After stlink, then you can Rewheel with encrpted file 5040, if you don't have the 5040 file then no point going any further.
        What was your goal try to get into factory mode?
