    Gt BMS unlocking
      abignoli last edited by
      So recently Avaspark released a product (avs RGB gen 3 gt) that can communicate with the factory BMS, and forward it's data to vesc. In this case I'm trying to use my gt BMS with a ubox 85. Unfortunately I think this only works if the bms hasn't been "bricked" or unplugged from the battery. However the developer of this board has also added a way to factory initialize the bms and "un-brick" it. However, it requires the factory authentication keys to be input in order to do so. I've been trying (unsuccessfully) to un-brick my BMS so that I can use it in this configuration, I was hoping that maybe someone here has the know how to be able to find the factory GT bms keys so that I can accomplish this. I found what I thought was them here, on this GitHub page.
      https://github.com/Relys/vesc_pkg/blob/float-accessories/float_accessories/lib/bms.lisp#L4
      But when I try those numbers it does not work, it looks to be wanting a hex address. Or a 16 character alphanumeric key.
      If anyone is skilled enough to help me with this, I don't mind sending some money your way. I'm at a loss. Yes I could buy an aftermarket bms, but I really want this to work as I can forward cell data to the vesc this way without buying an expensive smart BMS, or just deal with being stuck with a "dumb" charge only BMS.
      OneDanGTS-XL T 2 Replies Last reply Reply Quote 2
      • OneDanGTS-XL
        OneDanGTS-XL GT-S GT Pint X XR @abignoli last edited by
        @abignoli I know nothing about unlocking a BMS, LOL, but being a software developer, I do know hex, so this line:
        (def key-crc '(3141361152u32)) ;AES-128 key. Offset in 6109: 0x12009
        contains:
        3141361152, which if converting each number pair to hex is 1F29240B34 . . . so you can try that
        3141361152 converted as a full number to hex is BB3D5E00 . . . another number to try
        I've never used the lisp language, but hopefully one of those might work.
        Good Luck!
        A 1 Reply Last reply Reply Quote 2
          abignoli @OneDanGTS-XL last edited by
          @onedangts the offsets were locations within the official FM firmware. Problem is the firmware is encrypted, lol. Luckily, I found the right person who had the keys I needed and got it all to work! My factory GT bms is now reporting cell data to vesc. It's a beautiful day. Thank you for your efforts though!
          T 1 Reply Last reply Reply Quote 4
            Trickd122 GT-S @abignoli last edited by
            @abignoli Did you figure it out? Even in charge only mode? I have a GT and a GTS BMS. Wondering if you can share your experiences.
              @abignoli I just realized you reported it ll working. Would love to do this. Does it charge and discharge as factory?
