    Fresh Ubox Lite build on my first gen suspension board
      Lemur last edited by
      I survived the test ride on my fresh vesc build.
      New Ubox Lite, 22s1p 42 A cells , Maxkgo 30s bms and out of percaution I only charged to 90 volts instead of 92.4 volts and kept my speed to 16 mph for now.
      I had a warning on Float control about maxium motor voltage being too low but I couldn't change it as I believe that 95 v max is hard coded in the firmware, I not sure if a "no limits" is available for the Ubox Lite.
      I had a strange buzzing and harmonics on rocking back and forth on Refloat but smooth on Float, I have to check into that.
      This build was against all advice, but if you don't try, you will never know.IMG_8777[1].JPG IMG_8798[1].PNG
      L Puzz360 2 Replies Last reply Reply Quote 4
        Lemur @Lemur last edited by
        @lemur I've since updated the Ubox lite firmware to 6.05 "no limits" which allowed the Ubox Lite to have an higher maximum input voltage from the hard coded 95v to a higher value, in my case with 22s at 103v.
        Hopefully that will avoid the regen voltage spikes that will ND with the 95v input.
        The best feature with 6.05 firmware is the hill holding setting that matches a OW board, the vesc board is no longer rolling away on a slight incline.
        • Puzz360
          Puzz360 XR Pint V1 @Lemur last edited by
          @lemur Neat and tidy... Nice 👍👍👍
          M 1 Reply Last reply Reply Quote 2
            Mike sinclon @Puzz360 last edited by
            @puzz360 Got some good one wheels scooter I don't need anymore
