    charger do not fit anymore GT
      onewheelme last edited by
      Now when I plug the charger into my GT
      The cable is super loose, and just slides out.
      I can see the 3 pins, and when I try to gently "push them in"
      to see if the port in the inside is loose.
      They do not move.
      The board does not charge.
      But the connecting is super loose, and if I wiggle it.
      the onewheel starts,, but does not charge.
      What could be the issue ?
        Lia GT XR Pint Plus V1 DIY @onewheelme last edited by
        @onewheelme Could you share a few pics of the charge port and the charger connector?
        Also when it turns on are you able to connect with the app and see any errors?
