    DIY your onewheel with BMS
      jack yang last edited by
      Each S battery corresponds to each LED light. When the battery charge reaches balance, the LED green light turns on.
      403929441_1495548574577288_4089073645720367217_n.jpg 403851173_1495548531243959_4925494858437119383_n.jpg 403754449_1495548724577273_5867403163576092615_n.jpg 403746861_1495548567910622_2968983454803223241_n.jpg
        Lemur @jack yang last edited by Lemur
        @jack-yang I have a couple of Maxkgo bms's in my builds, the Zbms was always out of stock. the Maxkgo work fine and balances the cells nicely, the only downside is the balance wires and the jst ph connector as they are made of low temperature materials, very easy to melt with a soldering iron, doesn't take much to crush the balance wires. I recommend they be replaced with quality wires .
        I had a couple of evaluation "Pickles" 15s and 18s drop in bms, but they never charged the cells above 90% and two 18s-20s bms, but those two instantly "smoked" upon power connection. I'm pretty sure I fallowed the hookup sequence.
