    XR front lights intermittent
      lmaloney last edited by
      My headlights on my XR have been flickering randomly for some time now and within my riding group I have 3 other boards that do the same thing. It's only the front white lights that do it and the common led harness replacement didn't fix any of them. I took apart the board and started looking into the components powering the leds and found when the leds turn off in the flicker there is a 3-6V spike from 12V to anywhere from 15 to 18V. Has anyone looked further into this or might know what component on the board my be the cause?
        Lia GT XR Pint Plus V1 DIY @lmaloney last edited by
        @lmaloney Just in case. Have the connectors been resoldered yet? My personal XR had the front light issue but instead of the cable breaking the actual connector joints had cracked.
        Other than that if it helps here's a schematic I tried to throw together measuring parts on mine when swapping the bits. I don't have the inductor values sadly.
        Probably a more sensible way to lay this out but I'm still learning this stuff.
