    WTF rails
    • Puzz360
      Puzz360 XR Pint V1 last edited by Puzz360
      Re: Where to buy custom rails?
      Well, I’ve been looking on and off for a while for some WTF rails. They’ve been coming and going on the Craft & Ride site recently. Tonight I’ve managed to snag a set…
      Do I just need the Dig Tilt app once they are fitted or do I need to get anything else in place ?
      Edit. I meant the nRF connect app
      B 1 Reply Last reply Reply Quote 0
        biell DIY @Puzz360 last edited by
        @puzz360 What board, and if it is a GT did you just update the firmware? I don't know what the "Dig Tilt app" is, but I suspect it just makes digital tilt easy to configure. Assuming that is true, and your board still supports the BLE commands that make it work, then you just need to place the board (in a crate or whatever you have handy) the level you want. If you want straight, then make it straight. If you want nose down, then place it a bit nose down. After that, you use the app. Essentially all it does is tell the internal sensors that the board is currently level, so whatever their readings are now, assume that is level.
        Then, everything just works from there.
        Puzz360 1 Reply Last reply Reply Quote 1
        • Puzz360
          Puzz360 XR Pint V1 @biell last edited by
          @biell cheers… 👍 probably not going to update the board. However, let’s see what the feedback is when the XR update is available.
          Doh, forgot to mention it was an XR…. 😊
