    Pint x digital tilt recalibration...
    6371
      SEABASS last edited by
      Just installed a set of WTF rail on my new pint X going through the process of recalibration of my digital tilt and I got into "factory mode" with the first code had the green light then the board started flashing yellow and I went through the sequence of codes and never got another green light always flashing yellow 7 times. I get a battery too hot or too cold message and that's it. I can power the board off and ride it no yellow light. It only happens after I put in the 1st code CAEA in the process. Any thoughts anyone?...
        Lemur @SEABASS last edited by Lemur
        @seabass I believe someone with a GT encountered the same "too hot or too cold" error during tilt calibration ".
        I believe he sent his Gt in for repair, FM replaced his controller and may have updated his firmware that locks out "factory mode" . GT firmware can be rolled back. Your case may be different .
        What is your PX firmware?
        Your board should be at the tilt you want before trying nrf or Digtilt.
        -Confirmed ** That "too hot and too cold " error was due to using nrf on a Gt with the newest 6132 firmware**
        S 1 Reply Last reply Reply Quote 2
          SEABASS @Lemur last edited by
          @lemur version says 2.6.13 I really don't want to ride in elevated x mode all the time it would suck to have to send this back to FM I ve had it 3 weeks amd already voided warranty by changing out the tire opening the battery box and fixing the case issue by the balancing wires and weather sealing everything
            @seabass That's not your firmware, it's under diagnostic page in the app, should be 5076 if it hasn't been upgraded, picture is from my Pint firmware 5040IMG_7232[1].PNG
            S 1 Reply Last reply Reply Quote 1
              @lemur mine is 5092
              L 2 Replies Last reply Reply Quote 1
                @seabass Yikes! That's new, and there's no rollback, if that's true and there's a new firmware, then factory mode is locked out and no tilt calibration is possible.
                Cloud 1 Reply Last reply Reply Quote 1
                  @seabass Can you take a screenshot of your diagnostic page with the firmware? I would like to confirm to warn other PX owners. Thanks.
                    @lemur how do you post a picture on here ?
                    L Lia 2 Replies Last reply Reply Quote 1
                      @seabass When you're posting, the last icon in the roll of icons is the image icon.
                      Someone else on FB has also confirmed the new firmware is 5092
                        Lia GT XR Pint Plus V1 DIY @SEABASS last edited by Lia
                        @seabass
                        This icon in case you can't spot it :)
                        • Cloud
                          Cloud @Lemur last edited by Cloud
                          @lemur Is it not possible to downgrade on newer firmware?
                            Lemur @Cloud last edited by
                            @cloud You can down grade the Gt, XR, Og Pint as the ota updates were available publicly , but PX never had a ota update, besides FM closed that window when Rewheel was forced to shut down.
                            Now FM is shutting out nrf.
                            Cloud 1 Reply Last reply Reply Quote 0
                            • Cloud
                              @lemur said in Pint x digital tilt recalibration...:
                              Pint X OTA are possible, Just seems to cause many, many, many issues. ST-Link seems to be the safe way to go. A couple of people I had that tried most of the time had to ST-Link but works.
                              S L 2 Replies Last reply Reply Quote 1
                                SEABASS @Cloud last edited by
                                @cloud is there a walkthrough somewhere you can point me to or am I going to have to see if FM will recalibrate my board with the WTF rails installed......
                                L Cloud 2 Replies Last reply Reply Quote 0
                                  @cloud Doesn't the st link require a firmware that's been extracted from someone's Px stm 32 to write to yours?
                                  Ending up with a donor firmware that has that serial number and mileage.
                                    @seabass Fm won't touch your board with wtf rails on it.
                                    S 1 Reply Last reply Reply Quote 0
                                      @lemur I just called them and that's what they told me, why do they do this to us!?!? Looks like this board is getting ridden in elevated x mode until I can buy an old XR and mod that thing out.
                                        @seabass The other option is to convert your Px to a Rewheeled Og Pint with a Og Pint controller and bms.
                                        That way you can still revert back to a stock PX when you want to sell it (low mileage too) and the Og Pint controller/bms will bring in money.
                                        I'm sourcing a bms to complete a Rewheeled Og Pint controller for a friend that bought a new PX , wtf rails that has 5076.
                                          @lemur I'll have to research into this, this board is new I have 60 miles on it. Sucks that we have to find ways around to modify things we bought because the manufacturer doesn't want us meddling with their stuffs.
                                          • Cloud
                                            @lemur I hear bob has it.
