    Tensión de batería
      ImgerMg last edited by
      Se puede comprobar la tensión de batería en el conector del xr suelto?
        Lia GT XR Pint Plus V1 DIY @ImgerMg last edited by Lia
        @imgermg If you can turn on the board you may be able to use the OWCE app to check voltage.
        https://owce.app/install
        If not the only other way to measure is to take it apart and measure with a multimeter at the battery connector.
        I have labelled the 2 pins you can measure without unplugging the battery but be careful not to short them.
