<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help XR ERROR 16]]></title><description><![CDATA[<p dir="auto">I’m getting error 16 on XR. I have replaced the harness and still receiving error 16. Not sure what my next step should be. Any advice ?</p>
]]></description><link>http://owforum.co.uk/topic/473/help-xr-error-16</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 18:02:19 GMT</lastBuildDate><atom:link href="http://owforum.co.uk/topic/473.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Nov 2024 13:19:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help XR ERROR 16 on Sat, 02 Nov 2024 16:26:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/430">@cjbguam</a> Not dumb at all :)</p>
<p dir="auto">Assuming U17 on the controller side is broken then an  Owie chip won't change anything sadly.</p>
<p dir="auto">If you need someone to take a look at this Justin over at <a href="https://www.fixmypev.com/" rel="nofollow ugc">https://www.fixmypev.com/</a> has dealt with some of these in the past and offers repair so in the worst case he should be able to perform a repair.</p>
]]></description><link>http://owforum.co.uk/post/6516</link><guid isPermaLink="true">http://owforum.co.uk/post/6516</guid><dc:creator><![CDATA[Lia]]></dc:creator><pubDate>Sat, 02 Nov 2024 16:26:16 GMT</pubDate></item><item><title><![CDATA[Reply to Help XR ERROR 16 on Sat, 02 Nov 2024 12:34:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/1">@lia</a>  thank you for the advice and for adding the links. I have a question, maybe it’s a dumb one. Would an OWIE CHIP be a solution to my problem.</p>
]]></description><link>http://owforum.co.uk/post/6515</link><guid isPermaLink="true">http://owforum.co.uk/post/6515</guid><dc:creator><![CDATA[cjbguam]]></dc:creator><pubDate>Sat, 02 Nov 2024 12:34:13 GMT</pubDate></item><item><title><![CDATA[Reply to Help XR ERROR 16 on Fri, 01 Nov 2024 15:36:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/430">@cjbguam</a> If the harness checks out completely then the RS-485 Transceiver either side of the harness may be broken.<br />
On the controller side it's marked u17 and on the BMS it's IC5 beside the smaller of the white connectors.</p>
<p dir="auto">You can replace these. I would suggest the one controller side has likely gone as I've not personally seen it occur the other end. I documented a repair in the below archived topic if it helps.<br />
<a href="https://archive.owforum.co.uk/topic/9405/the-dreaded-error-16-code#37" rel="nofollow ugc">https://archive.owforum.co.uk/topic/9405/the-dreaded-error-16-code#37</a></p>
<p dir="auto">On retrospection knowing what I do now I had issues replacing the chip because my iron was probably too hot and damaging the replacements but after going through a few I got it working by swapping U17. Either of the below should work but if you know which you're actually have then try source that one specifically to ensure interoperability. FM changed supplier between revisions.</p>
<ul>
<li>STMicroelectronics <a href="https://www.st.com/resource/en/datasheet/st1480ab.pdf" rel="nofollow ugc">ST1480AB</a></li>
<li>Texas Instruments <a href="https://www.ti.com/lit/ds/symlink/sn65hvd1781.pdf?ts=1629578302424&amp;ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FSN65HVD1781" rel="nofollow ugc">VP1781</a></li>
</ul>
]]></description><link>http://owforum.co.uk/post/6513</link><guid isPermaLink="true">http://owforum.co.uk/post/6513</guid><dc:creator><![CDATA[Lia]]></dc:creator><pubDate>Fri, 01 Nov 2024 15:36:46 GMT</pubDate></item></channel></rss>
