<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error yellow 17 hot or cold with normal temp]]></title><description><![CDATA[<p dir="auto">Hello there</p>
<p dir="auto">I just bought 3 weeks ago my Pint X and now every time i ride on it i get hot or cold warning altho my battery is around 30C or90F<br />
I live in Europe and so far my best option is to ship it back to FM.<br />
I know it must be a sensor or something like this but can't do anything with it.<br />
Any idea? I am desperate.</p>
]]></description><link>http://owforum.co.uk/topic/142/error-yellow-17-hot-or-cold-with-normal-temp</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 05:12:23 GMT</lastBuildDate><atom:link href="http://owforum.co.uk/topic/142.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Jul 2022 11:30:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Thu, 21 Jul 2022 16:50:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/30">@samuraipunch</a> I don't want to change the battery now, but have to do it after like 5 years or something, and would be great if i don't have to send it back for that</p>
]]></description><link>http://owforum.co.uk/post/2510</link><guid isPermaLink="true">http://owforum.co.uk/post/2510</guid><dc:creator><![CDATA[agyas]]></dc:creator><pubDate>Thu, 21 Jul 2022 16:50:14 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Thu, 21 Jul 2022 00:59:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/40">@agyas</a> You can change the battery in a PX... but why and how? There isn't anyone making replacement batteries for them to my knowledge. And it's not like there's a better battery option either. It's so crammed full already, noone's going to figure out an impossible way to put 15 more 18650's in it. The only other option would be to use 21700's but you'd go from a 15S2P to a 15S1P for that, and effectively have a Pint w/ a Quart battery; basically half the range.</p>
<p dir="auto">I'd still try to return it, or resell it when it comes back.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/3">@NotSure</a> I don't see why you couldn't wire up a different/vesc compatible plug/harness from OWIE to a lil f'er... Although if you did, you don't really need the bms/controller communication... Besides your board/bms management would mostly be done through OWIE, and charging would probably look like a VNR setup into the BMS, so it should balance as well... I'm pretty sure there are some kits that maintain the FM BMS, and replace everything else</p>
]]></description><link>http://owforum.co.uk/post/2502</link><guid isPermaLink="true">http://owforum.co.uk/post/2502</guid><dc:creator><![CDATA[Samuraipunch]]></dc:creator><pubDate>Thu, 21 Jul 2022 00:59:22 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Wed, 20 Jul 2022 22:27:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/30">@samuraipunch</a><br />
Told them about the faulty desing and it wouldn't be great if i have to send it back from Europe every so often. They replied with a shipping reservation for me. So i just have to drop it off there.</p>
<p dir="auto">Will I be albe to change battery in PX or will it forget everything like the GT?<br />
Still as far as i know the PX is reliable, so i will be happy with it.  Just need a bigger tire and softer footpads.<br />
One thing i will miss is the 2 wheel at the front. I know i can buy for Pint but the pusback much more agressive so it's not that good as on XR.<br />
And i thought the XR is easier to fix in the long run.<br />
I'm not sure what to do if i get it back. Cause i could still sell it.</p>
]]></description><link>http://owforum.co.uk/post/2501</link><guid isPermaLink="true">http://owforum.co.uk/post/2501</guid><dc:creator><![CDATA[agyas]]></dc:creator><pubDate>Wed, 20 Jul 2022 22:27:34 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Tue, 19 Jul 2022 13:19:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/30">@samuraipunch</a> said in <a href="/post/2492">Error yellow 17 hot or cold with normal temp</a>:</p>
<blockquote>
<p dir="auto">4212's</p>
</blockquote>
<p dir="auto">if the vesc hardware had a way to communicate with a stock bms, im sure one could port over the owie stuff to a software plugin. an auxiliary serial port of some kind could be useful in general.</p>
]]></description><link>http://owforum.co.uk/post/2494</link><guid isPermaLink="true">http://owforum.co.uk/post/2494</guid><dc:creator><![CDATA[NotSure]]></dc:creator><pubDate>Tue, 19 Jul 2022 13:19:42 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Mon, 18 Jul 2022 23:25:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/40">@agyas</a> If you're in the EU you should be fine to drop it off at the retailer for "warranty". Although, they'll really serve as an in-between and ship it off to FM more than likely. You may be able to use the EU's stronger warranty laws to your benefit, in that it's defective. There's no if ands, or buts to it. PX has a flawed design that bites people. You got bit. Since basically NO RETAILER services OWs that's an authorized dealer, you'll be out a board if you intend to keep it.</p>
<p dir="auto">The XR is kinda meh imo, it's past its prime as your retailer likely has 4212's, and that limits your battery upgrade options down the line if you become interested. Otherwise it's ok...</p>
]]></description><link>http://owforum.co.uk/post/2492</link><guid isPermaLink="true">http://owforum.co.uk/post/2492</guid><dc:creator><![CDATA[Samuraipunch]]></dc:creator><pubDate>Mon, 18 Jul 2022 23:25:22 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Mon, 18 Jul 2022 20:36:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/40">@agyas</a> If I were you I would insist &amp; you can try that if you haven't opened anything &amp; if your Pint looks like new. Good luck!</p>
]]></description><link>http://owforum.co.uk/post/2491</link><guid isPermaLink="true">http://owforum.co.uk/post/2491</guid><dc:creator><![CDATA[[[global:former_user]]]]></dc:creator><pubDate>Mon, 18 Jul 2022 20:36:38 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Sun, 17 Jul 2022 21:05:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/30">@samuraipunch</a> that would be the best if i could get my money back. My local shop still have new XR. Can i ask a refund if i bought it 3 weeks ago, have more then 400km on it but it's faulty? Some scratch ofc but nothing serious.</p>
]]></description><link>http://owforum.co.uk/post/2481</link><guid isPermaLink="true">http://owforum.co.uk/post/2481</guid><dc:creator><![CDATA[agyas]]></dc:creator><pubDate>Sun, 17 Jul 2022 21:05:23 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Sun, 17 Jul 2022 21:00:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/40">@agyas</a>  For sure, send it back , once you open the board up , no warranty. Sounds like a thermistor or faulty thermistor wire  but there are no used PX batteries yet.</p>
]]></description><link>http://owforum.co.uk/post/2480</link><guid isPermaLink="true">http://owforum.co.uk/post/2480</guid><dc:creator><![CDATA[Lemur]]></dc:creator><pubDate>Sun, 17 Jul 2022 21:00:56 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Sun, 17 Jul 2022 20:48:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/40">@agyas</a> said in <a href="/post/2477">Error yellow 17 hot or cold with normal temp</a>:</p>
<blockquote>
<p dir="auto">stay safe and send it back</p>
</blockquote>
<p dir="auto">this ^^^^</p>
]]></description><link>http://owforum.co.uk/post/2479</link><guid isPermaLink="true">http://owforum.co.uk/post/2479</guid><dc:creator><![CDATA[NotSure]]></dc:creator><pubDate>Sun, 17 Jul 2022 20:48:18 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Sun, 17 Jul 2022 19:58:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/4">@lemur</a><br />
This is the must usefull thing a read anywhere. Thank you!<br />
First i got pushbacks and had to reboot to go a few miles or km with it. Today i could not move anything. Almost instantly getting the yellow 17 problem even with 27-31C around 90F.  So sometimes it can work yes. Yesterday it looked like i could go anywhere  but if i stop i may have to reboot to ride again. But later on i got pushback and had to stop.<br />
I sure this is the problem, but who would fix it for me? Or should I stay safe and send it back? I still risking the shipping money i guess. They will only tell is it faulty or I made the damage when they can see it.</p>
]]></description><link>http://owforum.co.uk/post/2477</link><guid isPermaLink="true">http://owforum.co.uk/post/2477</guid><dc:creator><![CDATA[agyas]]></dc:creator><pubDate>Sun, 17 Jul 2022 19:58:25 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Sun, 17 Jul 2022 19:28:02 GMT]]></title><description><![CDATA[<p dir="auto">The PX is a shit show in the battery compartment. All as a result of forcing a second set parallel set of batteries in. That the wiring and space management are causing problems due to cutting/stretching the wires in the various harnesses.</p>
<p dir="auto">Return it, and get your money back. As it's a faulty design and implementation that has dramatic hardware failure as its consequence.</p>
]]></description><link>http://owforum.co.uk/post/2475</link><guid isPermaLink="true">http://owforum.co.uk/post/2475</guid><dc:creator><![CDATA[Samuraipunch]]></dc:creator><pubDate>Sun, 17 Jul 2022 19:28:02 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Sun, 17 Jul 2022 15:02:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/40">@agyas</a> Did your PX  " captain morgan"  before displaying code 17?<br />
Is code 17  constant now or only after riding a bit?<br />
My experience with code 17 is with a JW battery on my XR, it would "captain morgan" , display code 17 , power cycle and would be rideable for a bit, then repeat the code 17.<br />
I ended up replacing all four thermistors in the battery pack and it's been fine ever since, however, your PX is still under warranty. Your Eurpean location makes warranties difficult though.<br />
There may other causes of code 17 other than a faulty thermistor, the bms connector/bms wires bms etc., opening up your battery box will void your warranty.<br />
The picture is a Pint bms with the battery bms wires, white wires on a OG Pint are the thermistor wires.<img src="/assets/uploads/files/1658070121534-bms-connector.jpg" alt="bms connector.jpg" class=" img-responsive img-markdown" width="1613" height="1210" /></p>
]]></description><link>http://owforum.co.uk/post/2470</link><guid isPermaLink="true">http://owforum.co.uk/post/2470</guid><dc:creator><![CDATA[Lemur]]></dc:creator><pubDate>Sun, 17 Jul 2022 15:02:25 GMT</pubDate></item><item><title><![CDATA[Reply to Error yellow 17 hot or cold with normal temp on Sun, 17 Jul 2022 14:04:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/40">@agyas</a> I can only hazard a guess but possibly the thermistor has a dodgy path back to the BMS so it breaks continuity long enough to trip the alarm. Severed cable, loose pin in the connector or the connector isn't in all the way would be possible culprits. That would explain why it shows within an acceptable range when you look. However repairing yourself would mean voiding the warranty to investigate and there is no guarantee of a fix in the event it's not hardware.</p>
<p dir="auto">If it's in warranty I'm pretty sure FM have to cover the costs of shipping. No harm poking them a  support ticket if you haven't already to check. <a href="mailto:support@onewheel.com" rel="nofollow ugc">support@onewheel.com</a></p>
<p dir="auto">Alternatively there are a few 3rd party repair places in Europe. I'm aware of <a href="https://www.pinkoak.co.uk/repairs?page=2" rel="nofollow ugc">PinkOak</a> in the UK who are pretty cool.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/25">@MacIak</a> <a class="plugin-mentions-user plugin-mentions-a" href="http://owforum.co.uk/uid/2">@ed_co</a> you guys know of anyone else in the EU that looks at Onewheels?</p>
]]></description><link>http://owforum.co.uk/post/2469</link><guid isPermaLink="true">http://owforum.co.uk/post/2469</guid><dc:creator><![CDATA[Lia]]></dc:creator><pubDate>Sun, 17 Jul 2022 14:04:22 GMT</pubDate></item></channel></rss>
